I have had this truck for 6 years and for some reason it is not starting. I turn the key and press the starting pedal and it just makes the starting noise like it’s about to turn over and start, but doesn’t. Battery is good and connections are clean. When it does start it seems like gas is not getting to the engine and if driving will start to stall when going to the next gear.
Welcome to VCCA Chat. I'll move this to a technical forum to get you a wider audience.
