#480656 04/14/23 11:28 AM
m006840 Offline OP
On the inside center sheet metal there are staples that held something between the inner sheet metal and the door skin. Anyone know what it should be and does it fit firmly between the door skin and inner sheet metal frame.
m006840 #480821 04/19/23 01:01 PM
Steve, attached are photos from an extra pair of 1950 hardtop/convertible doors I have. I see the staples but there was nothing attached when I bought this car.
[Linked Image from i.ibb.co]
Hawkeye #480827 04/19/23 02:11 PM
m006840 Offline OP
It does look just like mine . Most likely the upholstery installer will be familiar it. He did at one time work for HC The project is in limbo as I am waiting on the paint/body shop . Not many shops in the area that will work on "restoration" cars and I can't afford the ones that do.
m006840 #480832 04/19/23 03:12 PM
I too have an extra 1950 hardtop/convertible door with the same staples. The sound deadening material is missing from the one I have. Looking at the door that I have and the pictures above, the staples were all installed from the opposite side shown. Could they have been used to temporarily hold the sound deadening material in place prior to the door skin being crimped to the inner frame?
minetto #480837 04/19/23 07:40 PM
m006840 Offline OP
I agree whatever was stapled in was done before the door skin was attached. The sound deadening material on my 51 was attached with an adhesive-possibly an asphalt type product. I was thinking possibly a rubber bumper was stapled on to keep the door skin in place seeing it's such a large piece of sheet metal with little support. I could not find any reference in either the illustrations or index listing.
m006840 #480839 04/19/23 08:20 PM
Maybe rubber anti squeak? That's just a guess.
Tiny #480843 04/20/23 07:20 AM
m006840 Offline OP
I was going to say no but perhaps an anti-squeak for the window when down.
m006840 #480845 04/20/23 07:54 AM
I wouldn't think they'd waste the time and money to put the staples in for nothing.
Tiny #480859 04/20/23 02:38 PM
m006840 Offline OP
I agree and I prefer to know the answer before it's time to mount the door. I tried calling the Tech Advisor but got a message he is not taking calls at this time. I'll try an Email later today-just not sure the Tech Advisor is still active.
m006840 #480860 04/20/23 05:01 PM
If the window rests in that area when it's down I'd bet a cup of coffee it's an anti rattle/squeak device.
Tiny #480862 04/20/23 07:25 PM
m006840 Offline OP
I was able to get thru via phone but the TA was not there so will follow up in the AM.
m006840 #480879 04/21/23 11:14 AM
I’ve been wandering around Carlisle the past couple days and came across this Fleetline 2dr sedan door. It has the staples but no evidence of anything other than the sound deadner. Mike
111749D4-0A4E-43ED-A1BE-15275F71D11B.jpeg BE83AEC2-89DC-4EBA-B4FA-EDAC8D923297.jpeg 0A1C9AD3-E21F-4058-9C50-44E89AABF968.jpeg
m006840 #480882 04/21/23 12:14 PM
Interesting thread. By no means am I expert on these classic cars.
What I do know is that in the type of manufacturing and cost control environment Chevrolet had when they made these vehicles there was a reason for the staples. They would not waste the time and cost if those were not needed.
My best guess is that the sound deadener was stapled to the channel before the channel was installed in the fixture where it was welded into the door structure. It would be a lot easier and quicker to place the channel with that sheet attached rather than try to place the sheet and channel as 2 loose parts.
I can envision a process where the channels and reinforcements were spot welded together. Then the door skin was placed over that structure and welded into place.
m006840 Offline OP
I agree they had a purpose however the sound deadening material (waffle type felt paper) was attached to the inner surface of the door skin. The skin was crimped over the inner panel and spot welded in place. I have one door where the outer skin was replaced as it is tack welded on the edge of the crimp. There is also an early and late door shell but both have the staples . I did make contact with the TA and sent him photos so we will see if he can shed some light on the subject.
