#480610 04/12/23 08:36 PM
Hello can anyone point me to the site pro for parts interchange for my 33 Eagle, I have the interchange book but it is mostly worthless.... Thank you for any help you can provide me !!!
Bill Masters
Thank you for your reply, But what I am looking for is someone who can tell me if any of the body part on this car are interchangeable or if this is defiantly a one year only?? Thank you, Mike
This is kind of a general quesion.
It would be easier if you just post the questions here.
There are very few body or sheet metal parts for 1933 Eagle or Master cars that fit other years to make a long story short.
These are the body parts I am looking for: Running board brackets, front splash apron, Rocker panels, front door window garnish moldings, rear window garnish molding and a rear valence panel. Thank you in advance for any help you can provide me !!!
The front running board brackets are the same '33-'34 Master. The rear brackets fit '33-'36 according to the parts book I checked. Rear cross member cover for '33-'34 Sedans are the same. Didn't find other interchanges.
Hello and thank you for the info, Can you identify this car for me this gentlemen is parting it out and says the parts will work for me but it looks like this is a 34 or 35 standard to me. although as you can tell I am no expert when it comes to these cars....
Yes, a '34 or '35 Standard. If you could give us the job number off of the cowl tag, we will be sure. I looks too good to be parted out.
Bill Masters
That's what I said, it's so sad !!!!
Trying to get him to send me a pic of the job #, We will see...
With the alternately blacked out grille bars, it should be a '34 Standard. Unless there are serious issues that cannot be seen, that car should not be parted out.
I have a front apron for your car. I also have engine splash pans and possibly a tire cover for rear mounted spare.
Send me a private message or direct email for details and pictures.
Yes,it IS A 1934 sTANDARD . BENG A 4 DOOR IT WILL BE A LATE IN THE YEAR MODEL.
A lot of the parts would fit a 1935 Standard BUT NOT THE ENGINE.
Wow, that car is way to straight to be parted out, that is so sad!
Ed
The parting out of that car sounds like a scam. You are wise to get a picture of the tag.
1 member likes this: Stovblt
Excellent thought Dave!
With all the scamming going on, you are probably right.
Ole S Olson
