#480319 04/02/23 11:46 AM
I have a small water leak and I mean small. While doing other work I cleaned the back of the head area we’re I thought the leak might be. Then I found this area on the block with a lot of corrosion and pitted real bad. Is this a plug from casting or machining and is that a water jacket area. Not wanting to open bigger can of worms but if it gets worse maybe I will have an idea of what I will have to do. Every time I get an answer to a question I find 3 more questions. As always thanks for the help , advice and encouragement this site provides.
959FF431-6CD8-4666-A986-BD87521C4B9B.jpeg 2297D2DA-2DD2-4074-BBC2-70CA16D4EB35.jpeg
Kray1932 #480321 04/02/23 12:19 PM
Don't laugh at ths but if it were mine I would add cooling system sealer and not open a can of worms. The sealer like Barrs Leaks works well and will not plug-up the radiator core.
After that I would keep an eye on it and perhaps you can avoid major surgery.
Kray1932 #480325 04/02/23 02:07 PM
In addition to Genes suggestion I would drain the block and dry and clean the area (lightly) then apply a rust converter followed by an epoxy sealer.
Kray1932 #480326 04/02/23 02:22 PM
That looks like the steel core plug used to fill a casting hole. If it’s seeping it is rusted through and needs to be replaced. Likely when you remove it you will see how much sediment is blocking the water passages as well.
Kray1932 #480813 04/18/23 11:55 PM
After a good cleaning I applied a small amount of epoxy in the leak area. The next night covered out past the plug. Couple hundred miles no water leak. Thanks
Kray1932 #480815 04/19/23 03:06 AM
Support The VCCA!
Member Photos
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
Who's Online Now
4 members (Harrys31coach, Rustoholic, Rusty 37 Master, schudaddie55), 73 guests, and 43 robots.
Key: Admin, Global Mod, Mod
Newest Members
Chevrolet490nor, RickyMullen, CaptainD, orangeleeroy, PaulKennelly
18,043 Registered Users
Today's Birthdays
There are no members with birthdays on this day.
Forum Statistics
Topics58,551
Posts425,361
Members18,044
Most Online1,133
Jan 22nd, 2020
