#480123 03/26/23 07:09 PM
rons38 Offline OP
I have a Uncle in need of a cross member for a1936 chevy coupe standard, the one that master cylinder and transmission mount to. thanks
Would you be interested in a complete frame? I have one that came off a 36 cabriolet (standard series) that was being rodded. The rodder left the frame out in the weather, so it has surface rust, plus he bent the running board supports moving it around. But is is solid and definitely usable, stored in a shed. It is located in Virginia.
