#47991 04/07/05 09:14 PM
I have read methods of cleaning a gas tank on this forum, but today an unusual method was suggested. I am to buy 3 pounds of 1/2 inch nuts and throw them in the tank, remove the gas guage, fill the tank with fluid, strap it on a tractor tire, and drive for 1/2 hour. Supposedly this method will bring the inside to new metal clean. Anyone ever tried this? I am going to try this save any stern warning to the contrary.
#47992 04/07/05 09:57 PM
What kind of fluid are you supposed to put in the tank? :confused: :confused: :confused: :eek: :eek:
#47993 04/08/05 12:51 AM
I'd be real interested in the results.
#47994 04/08/05 02:38 AM
I would venture to say that the tractor will burn more diesel fuel than a professional cleaning job and the results will be better.
Agrin
#47995 04/08/05 06:42 AM
Ray, It's spring. The tractor will be burning fuel with or without the tank strapped to the wheel.
#47996 04/08/05 07:35 AM
Well, I have to admit that I find this post entertaining.
Yes, the use of 1/2 nuts, several pieces of small chain, or even sharp stones will clean the tank. You can use keroscene as the medium.
I have used this process for several years cleaning out old motorcycle tanks - but I have to admit - I do not have a tractor to tie my tanks too. Maybe that's what I really need to do a more effective repair....
You have a good idea and it should prove successful.
Oliver J. Giorgi
1958 Passenger Car
#47997 04/08/05 10:10 AM
Ollie,
If you bought this farm up here, then you would have your tractor!!!! LOL The next time you are here, I'll show you the tank I "cleaned" in my fire pit.
#47998 04/08/05 05:48 PM
DUUH, I tried that but used a riding lawnmower, didn't work,nope didn't work at all, every time the wheel rolled over the tank hit the ground and after a while it looked like a caved in metal basketball, what did I do wrong?????
devil bigl bigl bigl stressed
#47999 04/08/05 06:28 PM
xxx Offline
I have used the gravel that goes on a "poured" roof to clean out the insides of gas tanks and even glass jars and bottles.
croc
#48000 04/08/05 08:40 PM
Or you could do it this way and have some fun with the kids (grand kids). Pour pea gravel into the nasty old gas tank and add enough water to just cover the gravel. Take the tank, kids, or grand kids to the local park. Tie the tank to a teeter-totter and offer the kids a couple of bucks each to use the teeter-totter for a couple of hours while you read a book or sand on your next restoration project. Stop them every half hour and rotate the tank 90º. When you think you have the tank clean, pay the kids and take them home. Flush out the tank with water and let it air dry good. Then add you favorite sealant and let it cure.
#48001 04/08/05 09:30 PM
Maybe you could fill it up with your gravel or nuts and medium, put the gas cap on, and take it to the local Mexican resteraunt and let one of the dancers skake it like an instrument!!! That way you could eat, have a little fun, and get your tank cleaned all at the same time!!! Just a suggestion!
1939 Chevy 1 1/2 ton dually rear wheel pickup
1940 Chevy 1 1/2 ton single rear wheel pickup
1946 Chevy 2 ton cab and chassis
1977 Chevy 3/4 ton camper special 4x4
Obsessed 16yr old Chevy truck nut
#48002 04/08/05 11:43 PM
bottles, jars, nuts,Mexican food and dancers? WoW! I think I will just order a new tank, mine hardly fits since the riding lawnmower bit!
