#479875 03/21/23 07:18 PM
Looking for some input. I recently got my 31 trucks original 194 Stovebolt running. Friends are trying to talk me into installing a small block. With the cab being constructed of wood, I just don’t think the wood framing would hold up powered by a small block.
Thoughts?
NOOOOO !!
Do NOT listen to your friends.
Anybody can drive a truck with a small block in it.
Few can drive a truck with it's original 194 six in it.
It's yours to do with as you please, but I for one am begging you to keep it original.
Please.
Ole S Olson
1 member likes this: Clement
Could we see pictures please?
Pretty please? 🙂
Ole S Olson
Thanks Stvblt.
I was thinking the same but just needed som reassurance.
It runs strong. I took it around the block probably only doing 20 mph. 😂
See pics.
Motor
I don’t think this is the original bed based on what I’ve seen on the internet and would like to redo it
Thanks for the pics!
That is a beautiful truck.
You've got something that's getting rarer by the year.
As someone who drives an unmodified truck myself, believe me you will turn heads when you drive that around!
Ole S Olson
You are correct that is not a correct 1931 1/2 ton pickup box. But, you don't have a 1/2 ton truck but a 1 1/2 ton closed cab truck with and express body. It could be the correct express body (box) for your truck that has been modified.
FYI, the 1/2 ton has a 109" wheelbase. The 1 1/2 ton trucks have either a 131" or 157" wheelbase. Yours has the 131" wheelbase.
While finding some parts for the conversion you are talking about others are made of unobtainium and then you open a barrel of rattle snakes at least 1 of which will turn around and bite you. Take it back to original.
Nice truck! Anyone can hotrod a vehicle. All it takes is money. It takes dedication to keep one stock. What you have is a rolling piece of history. Don't be shy about making some changes for safety sake like putting brighter bulbs, adding turn signals and the like. I put a 6v alternator on my 38 but it's easily put back to the generator if my son (the eventual owner of the car when I turn in to plant food) wants to do that. I can just about guarantee that you'll be the only stock 31 Chevy at car shows.
Nice truck, keep it stock!
Ed
