Posts: 315 Likes: 2
Posts: 315 Likes: 2 |
Hello,
I need some help with the route the vacuum line for the Wiper motor takes on my 1940 Chevy PU. I believe it uses rubber tubing until it reaches the drivers side post. Does it use a piece of steel tubing up the post then continue with rubber?
Thanks,
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
Hi Mike
That is the way it was in my '46. I had a leak somewhere in the steel section. Because the steel section isn't actually visible, I wasn't overly concerned with complete originality. So... rather than tear all of the trim pieces out with the attendant clutch head screws, I was able to feed a new rubber vacuum hose through the A pillar from the top down and through the firewall to the manifold fitting. All one piece. Fewer places to leak.
Ole S Olson
