Posts: 470 Likes: 33
Posts: 470 Likes: 33 |
We have always had a leak between the exhaust manifold and the down pipe. The leak is in the rear of the pipe. Barely noticeable cold but noticeable once warm. When this car was built what kind of gasket if any was used between the manifold and the down pipe. We tried tightening the nuts but the rear nut seems to always loosen up slightly making this leak worse. The exhaust is able to move to allow for the engine's vibrations.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Exhaust donut. You can get them at any parts store.
Is the doughnut a standard size based on the pipe?
You might want to take the remains of your old one with you. Your exhaust pipe diameter is 1 7/8". The Filling Station sells both that and 2" donuts but you should be able to get them locally. If you don't have enough of a remnant to take with you just buy both and take the one you don't need back. They're only ~$5 each. http://chevy.oldcarmanualproject.com/chevyresto/4154.htm
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
FelPro 8592, $4.00 on Amazon
