Is there a way to find content I posted in the past? Thank you.
J Franklin
Yes. ;-) There are two ways to find your posts.
1. To see a list of all your posts, click on your screen name in your post above, a small drop down box will appear and one of the things you can select is 'Forum Posts'.
2. If you want to find a particular post about a particular subject, you can use the Advanced Search function (Advanced Search window), put in a search word or two (using a plus sign (+) in front of each word), and put your screen name in the By Display Name field. Then, you'll get a list of all your posts that contain those search words. Here's a write up on how to use the Advance Search function of this website: https://vccachat.org/ubbthreads.php/topics/366696/search-function-tips.html
Thank you, I see it now!
J Franklin
