Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
Hello Everyone,
In the process of "refreshing" my '37 MD 4 Dr. Sport Sedan. I am removing the doors to strip the paint. I had to remove part of the interior to access the rear door stop. Found a drain hose attached to the bottom of the pivot of the rear quarter window. This item passes forward down thru a gap between the inner fender and the door jam.
Has anyone come across this item in their journey of restoration ??
This feature was used at various locations.
Hello Chev Nut, This post I am asking if you would check out my post in the upholstery forum to answer a question about the inner construction of the front doors.
