Posts: 1 |
I bought a radio for my 32 Chevy got the receiver and speaker, but looking for the eliminator it’s my understanding your converts 6 v dc 200 V AC to power up the radio can anybody help me with this issue thank
scott phaneuf
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I think you mean the vibrator. Just google 6 volt radio vibrator. You should probably get a solid state one That are not as noisy as the old electro-mechanical units. Chev of the 40's has them.
I know they convert the direct current input power to AC but I doubt if it goes to 200 volts.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I haven’t dealt with a Chevy radio of that age but the early ones used a separate power supply box with what I would describe as a motor generator set to produce the high dc voltage. My 38 Master radio which I restored uses a vibrator. It supplies interrupted dc pulses to a power transformer which produces high voltage AC. That is fed to a rectifier tube that produces DC in the neighbourhood of 300 volts,
My 38 Master radio had a vibrator that was much larger than the newer ones. There is no replacement for them. I had to install a socket for the later style vibrator.
Posts: 97 Likes: 1
Posts: 97 Likes: 1 |
Is there a model number on your 32 or a schematic? Possibly inside cover
bill
