The 45 S has an extended tip. These came out when there was a lot of lead in the gas causing a engine miss at high speed. Extended tip was said to burn off deposits better. I believe they were discntinued years ago.
What we found is the entended tip burnt holes in the top of the pistons on 235 engines.
The spark plugs are seldom a startng problem unless they are foulded with oil Etc,
I would try different starting procedures like not touch the gas pedal, depressing it slightly, Etc.
Also A problem with the Petronix would, can and often is the problem.
