Posts: 18 |
'50 216. 12v. Stock, except for a split manifold. Carter W-1. Pertronix EI and their coil. Newish fuel pump. Runs great.
Lately, hard/won't start when hot. Cranks fine, just won't start. Gonna start with a plug change. Currently has R45. Is there an advantage to using the extended tip R45S?
And what else should I be looking at for the hard/ won't start problem?
The 45 S has an extended tip. These came out when there was a lot of lead in the gas causing a engine miss at high speed. Extended tip was said to burn off deposits better. I believe they were discntinued years ago.
What we found is the entended tip burnt holes in the top of the pistons on 235 engines.
The spark plugs are seldom a startng problem unless they are foulded with oil Etc,
I would try different starting procedures like not touch the gas pedal, depressing it slightly, Etc. Also A problem with the Petronix would, can and often is the problem.
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
Sounds like a problem I had a few years ago Engine ran very warm and the car would start missing and when I stopped it would not start again , It was vapor locking. I purchased an electric fuel pump and that ended all my starting problems when hot. (ethanol was the problem ) No problem now with cold startups either. And no 45s plugs
p.k.
