36dlc Offline OP
Has anyone converted their standard 6V headlights on a 1936 Chevrolet to LED? The headlight bulb socket on a 1936 is totally different than other years. The 6V LED bulbs being offered by the Filling Station will not adapt to the 1936 socket as far as I can determine.
Dave Cufr #12505
1927 Capitol coupe
1928 National 4-door
1928 Speedster
1936 Standard Town Sedan
1975 Nova Custom Hatchback
You can get the sockets to fit the LED bulbs from Restoration Supply in California. The LED bulbs work great, very bright and draw a fraction of the power. I can’t seem to attach a picture here. If you email me, I’ll send you a picture of the socket, mbd97@aol.com.
Matt Dickinson
Matt
ChatMaster - 5,000
ChatMaster - 5,000
My experience with LED headlight globes is that a match is brighter with 12v so doubt they would be any better on 6v. Most other lighting positions the LED system is by far better.
I have 6 volt LED headlamp bulbs in my 1935 Chevy Standard. They are a significant improvement over the original bulbs. I plan to install them in my '36 truck.
36dlc Offline OP
I believe that the 1936 car headlight sockets are different than the 1935 and the 1936 truck which leads to the probably of just changing bulbs.
Dave Cufr #12505
1927 Capitol coupe
1928 Speedster
I'm assuming the '36 Headlamp bulb is the type with the 3 pins. I believe they are called pre-focused bulbs.
I found an LED replacement for the 3-pin, flange mount, 2330 headlamp bulb for about $30.00 each. Here is a contact email address.
superlumination@cox.net.
I also have a 36 Master coupe and want to swap to LED's but am unclear if I can run them of my 6V generator as my car is all original or will I have to use a alternator ?
LED bulbs use less current than a conventional incandescent bulb. Enough less that my dash lights are noticably brighter because there is more current available to them.
36dlc Offline OP
Thanks for the input. I have ordered and received the 2330 headlight bulbs. I plan to install them when I get the "36 out in the spring.
Dave Cufr #12505
1927 Capitol coupe
1928 Speedster
ChatMaster - 5,000
ChatMaster - 5,000
My experience with LED headlights is while they show good light in daytime I would not try to drive at night, very similar to holding a match out front.
Support The VCCA!
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
6 members (Shorty, the toolman, duhen, 3 invisible), 35 guests, and 21 robots.
Key: Admin, Global Mod, Mod
Newest Members
Olfash12, GEORGE_YANDOLINO, Duane_R, ScaleSpeedGarage, PaulS
17,817 Registered Users
Today's Birthdays
AntiqueMechanic, awsumpt, ratrodnut1941
Forum Statistics
Topics57,589
Posts420,581
Members17,817
Most Online1,133
Jan 22nd, 2020
