#47802 07/15/04 10:06 PM
imwalt Offline OP
i have a '49 fleetline deluxe fordor. it was originally two tone, blue top and gray bottom. it was repainted biege at some point in time and the jambs were painted black with a brush. i;m trying to go back as close to original as possible and so i need to know if the jambs were originally two tone to match the exterior or were they one color, and if one color then what color would they have been? thanks walt
repainting door jambs
single choice
Votes accepted starting: 12/31/69 08:00 PM
You must vote before you can view the results of this poll.
#47803 07/15/04 10:23 PM
The door jambs would painted the same as the exterior---gray up to the belt line and blue above that.
#47804 07/24/04 12:01 AM
if it was two tone from the factory, then the jambs matched the exterior, but if it was painted by the dealer, then they may have taken a short cut and not painted the posts.
grease monkey, my foot
