Hello Everyone, I have a 47 Chevy Convertible that is in the final stages of restoration. The wipers work slowly and do not complete a full travel on the windows. The vacuum wipers have three vacuum lines at the switch on the dash, one from the manifold and two lines from the switch to the vacuum motor. If I want to use Gene's lubrication method, I assume I need to move the switch to the "on" position for ATF to reach the motor for lubrication. Just confirming before I try to lubricate the motor. Thanks
