#477402 01/06/23 03:25 PM
Rabaut Offline OP
Any idea as to what this tail light goes to?
necessary to see the other side
Rabaut Offline OP
C4E7BC88-2706-41FF-A563-30414B9C0F06.jpeg 82D21439-AB87-4D45-A52D-BE2349CEA93F.jpeg
From what I CAN SEE A 1935 MASTER, 1936-39 PASSENGER CAR left side.
Rabaut Offline OP
Thanks,
Much appreciated.
1935 and 1936 tail lamps are oval shaped. Your lamp is for '37 and '38 passenger.
That is correct.....had a brain freeze bonk
Mike,
The tail light fits all passenger cars and sedan delivery for 1937-38. It also fits a few 1939 Chevrolets - only the coach and sedan cars (these are the models without trunks) and the sedan delivery. All other 1939 Chevy cars used a different shape tail light with a round lens.
For reference, the light in your picture is different from the one used in 1940-53 trucks only at the rear mounting face. The lump on the back has a provision for a mounting screw which was used in cars, while a flat back design was used for trucks.
Unfortunately, it will not fit your 1940 truck.
Tom
Rabaut Offline OP
Thanks,
I had been given these under the assumption that they would fit my truckā€¦. There were small things that did not seem correct which is why I was asking.
Thanks to all,
Oh well
This on my 38 Roadster.
