#477125 12/28/22 06:58 AM
proud Offline OP
To keep with the original air cleaner, will a 51 Bel air 216 carb work on a 62 235 engine ? Thanks.
proud #477126 12/28/22 08:49 AM
I doubt it. The needs of the engines are completely different. The 235 would likely be in a consistent lean condition. If I'm wrong someone will chime in.
proud #477129 12/28/22 09:41 AM
The 235 and 216 carbs do not have the same mounting pattern-the 235 is wider.
