#476118 11/15/22 01:55 PM
badsix Offline OP
does anyone know where one might get a new horn button ? just need the plastic center part. mine has a couple cracks, can the soft rubber spring as to say be removed? it seems to be glued in rather firmly, it works now just looks bad. i don't want to make it worse by trying to remove the rubber. idea was to remove the rubber and glue the cracks from the inside then reinstall the rubber.
Jay D.
badsix #476122 11/15/22 03:01 PM
Did you try the Filling Station? I replaced the rubber and the button on mine. Looks good and works fine.
badsix #476213 11/18/22 03:13 PM
The Filling Station in Oregon
Early Chevy Parts in Missouri
