#476047 11/13/22 04:11 PM
piddler Offline OP
What were the octane ratings back in the 50's and 60's. I know there have been some changes in the way it is calculated because of the ethanol and being unleaded so I guess I am wondering what was available then and how a particular rating then compares to the same rating now.
I hope this makes sense.
Thanks, Pete
1951 styline deluxe sport coupe w/54 engine and power glide
piddler #476051 11/13/22 05:48 PM
And along those same lines, is it better to run no ethanol gas, even if the carb and fuel pump are compatible with ethanol?...
piddler #476055 11/13/22 06:28 PM
piddler Offline OP
The reason I am asking is because I am looking at a 65 Corvair with the 140 hp motor. Folks on the Corvair forum are saying I should run premium gas, especially in the summer, to prevent pinging.
Just doing a little research.
piddler #476057 11/13/22 07:06 PM
It doesn't say the specific octane but it does say any Corvair engine other than the 95 HP should be run on premium gas.
https://www.manualslib.com/manual/1035230/Chevrolet-1965-Corvair.html?page=35#manual
piddler #476061 11/13/22 08:53 PM
I run premium in my Corvair particularly in the warmer weather.
Chipper #476065 11/13/22 09:10 PM
I would use the preimum because if you have pre-ignition in your engine it can cause the hadened valve seats to fall out.
No use taking a chance.
piddler #476068 11/13/22 09:41 PM
We bought a new '66 Corvair Corsa, 140hp 4 carb engine w/ 3speed. It was a special order. We could have driven the same Marina Blue car home that day with a 4 speed--$64 option. My dad said--It's just another gear to shift...
