Posts: 3 |
How do you remove the armrest?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Most if not all have phillilps head screws that go through the bottom of the arm rest and screw into the door panel.
Posts: 3 |
Most I know, but not the impala.
While I've not personally done a 58, every Chevy arm rest I've done has been the same setup. The only difference is the spacing due to the size of the arm rest.
Posts: 337 Likes: 4
Posts: 337 Likes: 4 |
Just a wild guess for you! If you open the door, then get down on your knees and look at the underside of the armrest do you see 2 holes in the underside of the armrest? If so, get a penlight and shine it into each hole - you should see the head of a Phillips screw way down deep in each hole.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
There maybe a smoothing plug hiding the hole, these often have a small hole to pry it out and uncovers the screw holes. Tony
Posts: 3 |
Thanks guys. I'll check it out.
