A bracket was damaged and the frame bent out at that location.If the frame is level crosswise, are the brackets level also? Does anyone know the angles to the frame in the fore and aft direction? Someone suggested shimming the running boards to match the fenders. Would rather have things correct to start with. What do you think?
