#475285 10/19/22 12:48 PM
Floats Offline OP
Hi Guys,
I would like to know if 29 Chevy wheel bolts should be
chrome or painted?
Much appreciated.
Regards
Chris
Cape Town
Regards,
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats #475313 10/20/22 10:17 AM
Chris, it should be acorn nuts, painted black.
All the Best, Chip
"It's wise to choose a SIX"
Floats #475317 10/20/22 11:09 AM
Floats Offline OP
Thanks Chip,
Much appreciated.
I trust you are well.
Regards
Chris
Regards,
Chris
Cape Town
Floats #475320 10/20/22 12:51 PM
woo
I was wondering Studs or Nuts :)
Floats #475321 10/20/22 02:15 PM
Would black be correct for 29 wire wheels?
Floats #475334 10/21/22 07:51 AM
I finally found the picture I was looking for. Looks like they were chrome on the wire wheels. Lew Clark was the tech advisor for 29 for many years I would bet his car was correct.
Floats #475336 10/21/22 09:42 AM
Actually the 1929 wheel nuts were zinc plated. Same as the earlier rims and other steel parts. You will find them listed as galv. in some period documents.
Floats #475341 10/21/22 12:20 PM
Chipper,
Wire and disc the same?
Floats #475363 10/21/22 11:43 PM
I will try in the next couple of days to verify but currently believe the same nuts were used on both as they were exposed.
Floats #475367 10/22/22 05:48 AM
Thanks. If I am seeing it right in Lew's picture the nuts are not as reflective as the caps which would support zinc or cad. Synder's Ford parts has a couple of choices and the Cad plate is what they say is original on their cars. They look just like my rusty ones as far as shape have you seen those?
Thanks for your help.
Floats #475369 10/22/22 08:18 AM
The problem with cadmium plating is that it is just not as long lasting as zinc in wet environments, such as wheels. Electroplated zinc is generally not as thick a coating as dipped. Finding a zinc plater in todays business environment can be a challenge.
Chipper #475459 10/25/22 10:24 AM
I certainly defer to Chipper. Zinc plated rather than black. Now I have six cars with the wrong color wheel nuts. Now what? I hope somebody will send me 146 zinc-plated nuts. 144 for the cars and two for me.
All the Best,
Chip
2 members like this: Chistech, Dave39MD
Floats #475525 10/26/22 09:10 PM
On all the old photos from Chevrolet (and also one from MGM) that I have the lug nuts appear light, the same as the hub caps. I assume they were plated, even though all of mine had no sign of plating on them.
Floats #475534 10/27/22 09:01 AM
It is to be expected to have original lug nuts to have the plating at least mostly gone in 90 years. To determine what was done by folks that are surely now on their last assembly line makes the research a little more difficult. The fact that they left some photographs (a few without artistic enhancement) can be good clues in the search.
