My 57 Chevy Bel Air has factory power steering. The generator has part number 1102084 on the Delco Remy tag. I believe the Delco Remy generator is a 30 amp. Generator to support the power steering? I was told "non" power steering cars had a 25 amp. generator p/n 1119000, is that true? My Delco Remy voltage regulator is part number 11109003, and I believe it is also a 30 amp. voltage regulator.? At our recent Vintage Chevrolet Club of America annual judging event, one of the judges said the metal base on my Bel Air voltage regulator should be a silver color anodizing, where my voltage regulator has gold color anodizing finish. Which is correct? I have seen vintage 11109003 regulators on line with both silver and gold color bases. All of The non-power steering regulators p/n 11109000 I have seen have the silver base. Can anyone help me solve this mystery, and would the gold color metal base be a points deduction?
Len Yerkes
not sure about the finish on a 1119003 regulator but all 1119001 voltage reguators used on 56 and 57 Corvettes had a silver cadmium plated base and gloss black cover. the 1119001 stamping is in a straight line on original factory installed regulators. later service replacement 1119001 regulators will be stamped in two lines, the 1119 on a single line and the remainder, 001 will be on a second line of stamps. Originals will also have the date code stamped on the base. mike mccagh
Note that this post is in three different forums
All original Delco regulators that I have ever seen had a silver base
I've got a original 57 Bel Air with power steering. The tag on the generator is new and has no part number on it. How can I put the 1102084 number on it?
With very small number stamps. I do not know where you can find number stamps small enough but I am sure some one does.
