Posts: 23 |
after driving for maybe ten miles brake pedal got hard and lost any free pedal play 2-3 inches normally , let sit over night and free play returned , brakes unseized I'm guessing plugged master ??
Posts: 302 Likes: 4
Posts: 302 Likes: 4 |
Check relief port in M/C is open. Remove filler cap and insert fine wire in smallest hole. I am assuming piston returns properly when you release the pedal.This activity you can see in the M/C when you shine a torch inside and with a helper to push the pedal slowly. You can also remove the fluid with a medical shringe while you are there and fill with new fluid. Use paper towel inside the M/C to mop up the dirt inside. Dont push pedal while you clean the M/C out.
1 member likes this:
rjsautopro |
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Another cause is the rubber cups in the master cylinder have swollen and are now blocking the relief port (small hole). If this is the case a rebuild is required. These rubbers seal on the edge and if this is damaged they no longer work. Tony
rjsautopro |
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
While the above advice is right on, but in order to avoid all that trouble cleaning the MC up, you may try just driving it once a day and for less than 10 miles.  Just saying. Best, Charlie
rjsautopro |
Posts: 23 |
ty tyvm , my thoughts also , it has a rebuilt mc
Adjust master cylinder push rod etcentic as per shop manual demensions.
Posts: 23 |
thanks chev nut ill have to find a shop repair manual
