KevinT Offline OP
Hi all,
My 1930 three window coupe has a broken windshield. I need to remove it. It has a regulator and crank at the upper part of the window, which I removed. The windshield moved up and down. My question is, do I need to remove the top in order to remove the windshield and frame or is there a better way?
There are two moldings one on each side of the windshield glass channel held on by a few screws. Remove the screws on both sides and then you should see the glass channel against the wood post. You may have to run a thin sharp blade between the channel and wood to loosen them. Then tip the top of the windshield toward you. It may take a little tugging to get it to move. Be very careful of the broken glass as it has razor sharp edges. It goes back together the opposite of removal.
KevinT Offline OP
Chip you are the man!!! Thank you for all your help.
