Jtaoj0 Online Content OP
OP Online Content
Hi, there are 2 rubber strips used in the center of the two piece windshield when installing the windshield on a 39 master 85.
I have seen conflicting information on how they are used/ installed. Does anyone know of a diagram? Thanks Jeff
This is out of the 38 manual. The 39 is likely the same or very similar.
OP Online Content
Thanks Tiny. I have the 39 manual and it doesn’t have that picture. There isn’t enough detail on which center gasket is inside vs outside.
I and I reproductions shows the gasket with the center ridge as inside while Steele shows it as outside.
