1010 Offline OP
I have a 1938 Master Deluxe Sedan. It once had front knee action suspension. I removed it and installed a straight axle. I now want to go back to the knee action. I found a 1938 master deluxe coupe knee action front suspension the entire suspension. Question: Is the COUPE suspension the same as the SEDAN suspension and bolt right up? Same Mounting Bolt Pattern?
The 1938 Coupe and Sedans used the same knee action suspension.
