#472964 08/10/22 10:49 AM
Pops36 Offline OP
Hi group
Does any one know if or where I can get a coil for my 1936 Chevy Master coup. It has the ignition wire coming out of it to the switch. I believe it is failing because when I reach 50/55 the engine cuts out, so I roll of the gas just a little and then back on and it picks up as if nothing happened. No popping back firing or any thing.
Thanks'
Pop's36
Pops36 #472968 08/10/22 11:07 AM
I see you posted this in the mechanical forum. Most of us scan all the forums so you will get responses in both postings.
Pops36 #472975 08/10/22 12:07 PM
To test, just buy a 6V coil from AutoZone or similar, and wire it in to see if that truly is the trouble. If it is the coil this will keep you on the road until you find the stock type.
J Franklin
Pops36 #472980 08/10/22 02:23 PM
Pops36 Offline OP
Is that pretty strait forward to do as I'm limited with my electrical. What about the wire coming from the starter switch ?
Pops36 #472981 08/10/22 02:31 PM
It sounds to me like you should consider a fuel problem. A bad coil usually fails when it gets warmed up and doesn't work again until it cools off. Good luck.
Pops36 #472987 08/10/22 03:45 PM
Pops36 Offline OP
Thanks, I will start with that.
Pops36 #472994 08/10/22 05:16 PM
Both coils have 2 terminals that do the very same job, they are just placed differently. Look to see if there is fuel to the carburetor before changing the coil as mentioned.
J Franklin
Pops36 #472995 08/10/22 05:19 PM
Pops36 Offline OP
Copy
Pops36 #472997 08/10/22 05:27 PM
When I run into this type of trouble I check by bridging open points with a screwdriver with the ignition switch on and see if a good .spark jumps from the end of the coil wire to ground. Check the point gap and condition of the distributor while in there. Then I see if there is gas if I have spark.
J Franklin
Pops36 #473049 08/11/22 02:58 PM
Pops36 Offline OP
Great direction. I will give it a go.
Pops36 #482975 06/26/23 12:49 PM
Are there any original style coils available for the 36?
With the metal clad ignition wire and top cap?
Mine just failed over the weekend
Pops36 #482979 06/26/23 03:27 PM
I have a 36 good coil. When you say metal clad ignition wire and top cap are you talking about the Electro-loc?
Jon T.
Pops36 #483256 07/07/23 06:51 PM
Are NOS coils still like new or do they start to break down with age?
Black Bird #483258 07/07/23 08:17 PM
Generally speakng an old condender has a shelf life but a coil is oil filled and well preserved.
Pops36 #483269 07/07/23 11:31 PM
Thanks Gene
