1941 Master Deluxe, 6v generator.
What parts under the hood should be lubricated, with what and how often? Everything is as it was in 41 to my knowledge.
Usually anything needing lubrication will have an oil cup or grease fitting, maybe a little cam lube on the distributor cam also. The steering box may have a plug. It might be helpful to buy an owners manual.
J Franklin
That is covered well in the front section of the shop manual with good descriptions, Reprints of the shop manual and owners manuals are available from the www,fillingstation.com
