#471887 07/12/22 09:10 AM
old216 Offline OP
Several years ago I installed an Oakie bushing in my 38 Master. I did so because I think the drive shaft seal was leaking. The part was not new and now it looks like the new seal in the Oakie is allowing transmission fluid to drain into the rearend. So this winter I am going to pull the torque tube. I am now trying to figure out how to remove the Oakie. It took a lot of force to install and I really don’t want to use a lot of brute force to push it out. I am also wondering if the torque tube will have been stretched some in that area,
There is a bushing removal tool available for rent or purchase from the Filling Station that should do the job. Their web site is www.fillingstation.com.
1936 Chevy Std
1954 3600 Truck
2008 Corvette Z06
Here is a video link:
Mihaly
