#471869 07/11/22 02:47 PM
Is there a special nack to unsoldering the capillary tube that runs from the sender to the oil temperature gauge of a 47-53 truck and then reattaching it back to another gauge?? I would like to swap out the tattered cluster with one of nicer original condition.
Thanks in advance.
This club is terrific!!
I have no clue personally but I'll move this to a forum where you'll get more answers.
I you mean the oil pressure gauge it is just filled with oil. If the temperature gauge do not thoch it.
I agree with Gene. The water temperature sensing bulb and gauge function as a sealed unit. It is filled with ether. The pressure increases as the temperature in reases. That pressure increase moves the needle.There are a few specialists who can repair them.
I dont remember there being an "oil temp" guage as standard fitting (only after market fitting) in any Chev, the temp guage I know of was for coolant temp and as Gene said it is generally not a diy job to make work properly if the tube gets cut or broken.
