Disconnect the crank-out strap and take out the hinge screws to remove the windshield. Separate the two halves of the frame by removing the T brackets at top and bottom. Remove the old glass (keep whole for pattern). Clean the channel and make repairs as needed. Install new glass with appropriate setting tape which should be available from your local auto glass shop. Re-assemble frame and re-install in your truck.
Alternate method is remove from truck, deliver to aforementioned glass shop, wait for call telling you it is finished, stop for Ice Cream on your way to pick it up, smile while you pay inflated bill, reflect on how stress free the experience was, reinstall in truck. This is my preferred method.
