Posts: 217 Likes: 3
Posts: 217 Likes: 3 |
Hello All, I usually post with questions about my 51 but now I'm helping a friend with his 63 409/425 car. I'm going to re-plate the master cylinder cap (the rest is going to White Post for sleeving and rebuilding). I need some help with the plating finish type. 1. Is the cap itself plain cadmium/zinc? Or is it also yellow dichromate over the zinc? 2. Is the thumb screw also plated or is it just bare steel? 3. There is another piece under the thumb screw, like a formed washer, that has some evidence that it was yellow dichromate. Is that how it should be? Or was it also just zinc/cad? I can do all the plating and dichromate wash myself but I want to do it with the correct original type plating. As always, any help is greatly appreciated. Jeff
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
The cap is zinc or silver cad as well as the washer the thumb screw is natural steel. John
John
Posts: 217 Likes: 3
John, Thanks for the response. That is what I was thinking. Jeff
Jeff
The problem is finding a good cover without any pits for plating. If you can find a Corvair in a salvage yard that has an original master cylinder, they use the same cap and are usually protected much better, and make a great core for the cap
Good luck John
John
2 members (modiol, 1 invisible),
63
guests, and
7
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
