Page 2 of 2 1 2
What is the maximum inside diameter from the brakedrums?
I have a deep scratch in the brake drum now had to have turned out for this I need to know the maximum allowable inner diameter
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
Hallo Andre,
Hopefully one of the experts will find a specific reference for the brake drums on your Chevy. I could not find that data in the shop manual or the specifications.
The normal limitation is that a brake drum cannot be turned to an inside diameter that is greater than .060” (1.5 mm) above the nominal or new size of the drum.
On your car the nominal or new size of the drum is 11” (280 mm).
Russell #38868
'48 4 door Fleetline
My brake drum is pretty much still 11". The groove is 0.25mm (0.0098") deep, so turning it out should not be a problem. At the moment I leave it so, because the groove is already very old. I suspect there once a rivet of the brake pad has worked in. But it was not this lining, so already much older. Also do not think that makes a difference to the braking performance.
Greetings André
Many years ago here in Aus 1/32" oversize linings were available but I believe they have been deleted from all inventories now.
Hallo Andre,
I agree with your assessment that the groove is not a concern. I would not turn the drums at this time unless you can determine they are put-of-round.
I hope you can get your car back on the road soon to enjoy the summer in it.
Hello Rusty,
I hope so too. It's been almost exactly 6 years since the start of the restoration, so it's about time to experience this car. But at the moment most of the work is done, just bleeding the brakes and some cosmetics in the interior. Last but not least, I still have to clear the German TÜV hurdle, but that shouldn't be a problem.
Greetings André
Until the shoes "work in" there will be the lose of contact where the groove is until the shoes have sufficiently worn down and contact the bottom of the groove. The difference in braking will not be significant enough for you to be able to tell the difference.
I recall Porche didn't advise turning the rotors/drums until a certain depth of grooves was reached. I don't remember what that depth was.
Best,
1 member likes this: Alligator
By the way, I still have a tip for all those who also want to change the wheel brake cylinder. Disassemble in any case the new and lubricate the components with brake fluid. One of mine had been assembled completely dry
Greetings André
Now I have a new problem. I wanted to bleed the brakes. A procedure that I have already done successfully on many of my cars. I followed the manual exactly and no more air comes out of the cylinders. Unfortunately, I can't get a stable pressure point. It always feels soft. Is there a trick to this? We have bled with two people.
Greetings André
Hallo Andre,
Sometimes I have had similar results if I did not adjust the brakes properly before I bled the system.
The other problem I have had is what the Chevy shop manual calls “toe clearance” for the brake pedal. You make this adjustment to make sure that the piston in the master cylinder returns completely to the home position when the brake pedal is released. In that position the small port between the piston chamber and the reservoir is open.
Hopefully you can get the brakes working properly.
Page 2 of 2 1 2
