#47102 05/22/03 06:29 PM
490k Offline OP
I'm using DuPont Centari Acrylic Enamal to paint my car. My question is how long does the paint have to cure before I can color sand. Is it the three months like it is before you can wax? Thanks :eek:
#47103 05/23/03 12:11 AM
Depends on how it is applied. Did you (or are you planning to) use catalyst? If so then color sanding can occur in a day or so. If not then it takes a up to a few weeks. Depends on ambient temperature on cure time uncatalysed. Use the catalyst. Makes a better job overall.
#47104 05/23/03 02:42 PM
I just painted my fire wall and ended up with lots of orange peel,I am useing a 2 part system useing a catalyst,Iam pretty sure my gun was improperly ajusted,its the first time I've used a gravity gun.I know it should be set at 10 p.s.i.chef - chevy
#47105 05/24/03 09:27 AM
490k Offline OP
Yes, I used a catalyst. Thanks for the info.
#47106 05/24/03 01:53 PM
chef-chevy,The instructions for my HVLP touch-up gun say orange peel is caused from gun being held too close to the panel. ok
#47107 05/24/03 10:34 PM
Could also be to thick paint or to little air pressure ,Try a little more pressure always gauge it at the gun ,some have a regulator on the gun . Make a couple dry runs on some scrap metal to find your trouble . those type guns will spray a nicer pattern with a little more pressure,but you will get more overspray.Good luck
woody
#47108 05/25/03 03:04 PM
I also think I have the gun set to spray too much material.I'll tell you it is no fun sanding off $75.worth of paint...Live and learn...I'm useing my larger HVLP gun,my detail gun (same type)sprays very nicely,all in the settings???chef- chevy
#47109 05/25/03 04:15 PM
With a HVLP gun it will put more paint on than you think due to the fact that there is little overspray ,its all on the car. Always make a test to check your pattern finish and paint buildup it will save time and money.I learned that when I started painting in 1957 .Try a little more pressure than what the EPA recommend you will find all the pro painters do this when no one is looking, its not legal in some states but it works, make sure the paint is thin enough and use the right thinner for the temp.
auto
woody
