Posts: 105 |
Hi. Does anyone have a handle on which year rocker arms exchange with a 1958 235 I have a really bad intake arm on cylinder 5 and have not found a replacement. I have a 1935 207 core engine, with the head, and the arms look similar, but smaller. I have not tried a fit yet. I have not had any luck online determining if other years are the same which could be used to replace the one I have that's bad . As a side question, has anyone had experience welding and re-machining an arm?? Thanks
Hainscou
1954 and up 235 rocker arms are the same.
Posts: 105 |
Hainscou
Posts: 201 Likes: 2
Posts: 201 Likes: 2 |
Aren’t ‘59-‘62 rocker arms different than the earlier ones?
Yes, the 1959 and up have the off set oil grove.
