I am working to install new fuel lines on a 1937 business coupe and curious as to what style of fuel clips were used, how many, and where were they located to keep the fuel line on the frame of the car?
Jonathan W. Ketron
1937 Master Deluxe Business Coupe
JK,
The best I can tell what you need is in group 8.950 in the parts book. There are two types listed
120521 1/4" Strap. Bolt-on Type and
148129 1/4 Hook, Push-in Type
I think my 41 used the latter one but could have used the former or both. I'm no sure.
Owing to CotFs listing their stuff by part number, you may want to give them a call.
Best,
JK....
My 37MD used the push-in clip.
Both the fuel line and brake line run along the passenger side of the frame - parallel to each other.
The fuel line runs on top, thus the brake line is on the bottom.
At or near the cross member a brake line T allows the line to go to the master cylinder and to the front brakes.
I must have found the clips locally ... I don't find the items listed on any of my FS or C40s invoices.
If you want, I can count how many I used for both lines.
rgds, jim
Another possible source for brake and fuel lines including clips is inlinetube.com.
1936 Chevy Std
1954 3600 Truck
2008 Corvette Z06
I purchased mine from CoF.
VCCA # 047832
Originally Posted by 41specialdeluxe
JK,
Best,
Charlie, thanks for the information!
Jonathan W. Ketron
Originally Posted by Jim37MD
JK....
rgds, jim
Jim,
Great info thanks so much! Yes, could you please count how many you have for both lines. Do you have any pictures of your set up? Before I purchased, the previous owner installed a rubber line. I am working today to install pre-bent steel lines just like the factory did. Any help would be great as I can find no info in literature as to what the set up looked like for a business coupe. Imagine the sedans were similar, just had different gas tank placement. Thank you!
Jonathan W. Ketron
Gentlemen thank you for the suggestions. I will look over both filling station and chev's of the 40's. Here is what the filling station has in their 2022 catalog. Any of these look like the 1937 stock clips?
Jonathan W. Ketron
Jonathan ...
send me a private message with your email address.
I'm unable to attach fotos in this forum.
The 3889/3890 look like my clips.
rgds jim p
Jonathan ...
rgds jim p
Hi Jim, sent you a PM message. Thank you!
Jonathan W. Ketron
