I had my '36 standard transmission rebuilt several years ago, but just recently installed it.
Without the drive shaft disconnected, it appears to work fine, however with the drive shaft connected I get a rotational "clunk" sound in first gear, and a "searing" sound in third. Second and reverse sound OK.
I thought it was the speedometer gear bouncing off the drive gear, however when I removed the speedometer gear from the case, it still makes the noise. I replaced the u joint, which made no difference. When I slide back the u joint ball housing to see the exposed u joint while the the car is running (on jack stands) it appears to "hop" about 1-2mm, and still makes the noises. The drive shaft spline shows no lateral movement, so I think the bushings are OK. Any ideas?
Thanks, Steve
