Posts: 39 |
Temp gauge doesn't function so wonder if an aftermarket mechanical unit will screw into the engine block inlet? What is the fitting size?
TedG
Posts: 39 |
Understand Roy Martin was the go to guy to repair the temperature gauge. I called and unfortunately he has retired. Any other leads?
TedG
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
There is info on line on how to repair your old gauge providing your gauge at the instrument panel is OK. it involves purchasing a new mechanical capillary tube gauge that has a similar size bulb and splicing the tubes together . That is done with the new bulb sitting in a container of ice that encapsulates the bulb. I am in no way recommending you try that as it is not something I have done but it did make for interesting reading. I believe NAPA and other auto stores sell the new gauges. When I worked for an equipment dealer we used to purchase them locally and I don't ever remember having a customer that had a problem installing one so i am guessing the fittings are a fairly standard size.
Posts: 39 |
It would be nice to have the original gauge functional but it appears to be a challenge. An aftermarket replacement may need be but it's not likely to look period. More important the car is functional and eliminate the threat of frying the engine unintentionally.
TedG
Posts: 4,373 Likes: 30
Posts: 4,373 Likes: 30 |
Wow, Roy recently did the one on my 1930 not that long ago, :!)
superb job, and quick turn around !!
as noted there were several places that stated they did the same. some listed in the AACA Mag and can google search them as well. i read the how to and figured i would leave it and pay someone that knew what they were doing and could test it for accuracy.
Posts: 39 |
Actually I had used Bob's speedometer in the past. He restored a speedo cable for me and it turned out great. I didn't realize he could also do gauge repair. Appreciate the lead. Will follow up on it this week!
TedG
Posts: 71 Likes: 2
Posts: 71 Likes: 2 |
Did you happen to get the gauge fixed? I have a gauge stuck on cold and looking to repair. I see one on eBay currently but pretty pricey.
Posts: 112 Likes: 2
Posts: 112 Likes: 2 |
Unfortunately I didn't. Seems those that had the know how have retired. Apparently the tube leading to the block is filled with some kind of a gas. For now I have one of those remote guns to aim at the block that reads temperatures.
Posts: 71 Likes: 2
I’m curious what temp ranges are you looking for when pointing the temp reader at the block?
Posts: 112 Likes: 2
Between 140 to 160 degrees.
Posts: 4 |
My gauge also does not work, Thinking about mounting an aftermarket gauge, but don't want to loose the original look. Does anyone have any leads on who might have a gauge or if Roy has retired where to go to get one fixed. If somebody would care to walk me thru removing the gauge from the dash it would be appreciated.
Roy is retired....
here is a list of places i talked with that do the repairs on these older capillary type temperature gauges.
D&M Restoration 57-B Creekside Park Court Greenville, SC 29615 Monday-Friday: 08:00 am – 05:00 pm Saturday & Sunday: CLOSED 864-254-9989 support@dandmrestoration.com
Mo-Ma Manufacturing 1321 2nd Street NW Albuquerque, NM 87102 Monday-Friday: 08:30 am – 04:30 pm Saturday & Sunday: CLOSED (505) 766-6661 jlobo@momamanufacturing.com
Gold Star Restorations 5780 Pacheco Pass Hwy Hollister, CA 95023 Monday-Friday: 00:00 am - 00:00 pm Saturday & Sunday: 00:00 831-636-3020 Gauge@gold-star-llc.com
Instrument Services, Inc. 4075 Steele Drive Machesney Park, IL 61115 Monday-Friday: 08:30 am – 04:30 pm Saturday & Sunday: CLOSED 815-316-2921 sales@clocksandgauges.com
Bob’s Speedometer 10123 Bergin Road Howell, Michigan 48843 Monday-Friday: … Saturday & Sunday: … 810-632-0400 …
Posts: 112 Likes: 2
Posts: 4,021 Likes: 99
Posts: 4,021 Likes: 99 |
Great reference information,
Thank you BearsFan315!
When I call I asked can they service, repair, rebuild a vintage temperature gauge - capillary do they validate and test every gauge when done to validate temperature and range on the gauge face time of turnaround est cost to eval and service
the list was current when i called and had mine from my 1930 redone late 2020. Roy did mine, all new capillary tube and bulb, superb job. must have been one of the last ones he did.
Posts: 4 |
Thank you BearsFan 315 that is some good information, with those leads i should be able to find somebody to repair mine. Thank you very much.
Topics59,071
Posts429,069
Members18,308
