#469937 05/19/22 08:54 PM
TG1931 Offline OP
The dome light on my 31 Independence had never worked. Now suddenly it has popped on and I cannot find a means to turn it off! Any suggestions? Attempted to access the bulb but can't figure out how to remove the cover.
Also - Where are the headlights grounded? Obvious mine have a loose connection because they vary in light intensity.
There should be a switch on the passenger side B pillar (at least there is on my 4 door). When on, the switch connects ground to the light. Perhaps your switch has shorted.
This post is guaranteed to be 100% content free!
'31 Special Sedan
TG1931 Offline OP
I'll take a look see. The entire wiring assembly has gremlins it seems.
TG1931 Offline OP
Found it! Thanks!!
