#469515 05/03/22 08:51 PM
Rossco Offline OP
the bolts on back main bearing are 7/16 is the torque 70 pounds
That sounds like a lot. 1/2 - 13 head bolts are only torqued to 55 or so.
1/2" head blots are torqued to 70 pounds on 216 engines abd 105 on 235 engines.
Rossco Offline OP
What would be the correct torque
Torque values were not given in 1934 as no one even had a torque wrench.
Looking at later years for a 7/16" bolt I would use 70 foot pounds.
Note that in the later years where torque is given it states "with oiled threads".
