While removing the rear fender side stainless from my 55 Belair during restoration a small area of the panel above the wheel house "oil canned" curse in. It can easily be pushed out from the inside and shows no signs of any damage, this car is rust free and never been hit. Seeing the molding held it place all these years I guess I can reinforce the back until it's painted then when the molding is reinstalled it should hold. Is this a common problem in these long fenders and is there a way of fixing this problem? Also does anyone know a paint code or seen a fizz can to finish the inside of these side moldings, it looks to be an off white? Thanks for the help
