Did engine swap on my 1950 Styleline Deluxe. Pulled the 215 and put in a 1956, 235. Swapped the flywheel and bell housing. Now the starter seems "tight". When starting it seems as if it is binding. It will start, but the binding bothers me. It is converted to a 12 volt system (see 12 volt conversion gone haywire) and all new wires and a fuse box. Yes a real fuse box. I am using the original 6 volt starter. I know there are Chevy starter shims that I used in the 60s. I don't know if this would be an answer or not. I am open for suggestions.
PS: While I got "down time", I'm putting new "stuff" in the front end. She was getting a bit sloppy.
