Posts: 4,022 Likes: 99
Posts: 4,022 Likes: 99 |
I suggest that you study this wiring diagram. Based on what I can best determine turn signals were a dealer installed accessory for trucks in 1954. This included adding a second dual filament taillight to the right rear of the bed. Your latest picture only shows 3 wires in the harness from the steering column. There should be another 3 wire harness going up to the turn signal switch. It has white, pink, and purple wires. 1954 Truck Turn SignalsI am completely confused by the double dual filament tail lights. Until you can trace all the wires to all the filaments I doubt if I can offer much more guidance.
1 member likes this:
OldNifty50 |
Posts: 12 |
I think what I'll do going forward is rewire where I can, cover/protect it with aftermarket conduits and grommets. What gauge wire is recommended?
The tail lights were wired with 16 gauge wire. This larger wire was used because it was a 6 volt system and it was a relatively long length of wire to the taillights.
If your vehicle is really a 12 volt system and you are not concerned what could happen if someone converts it back to 6 volts, you can use 18 gauge wire.
OldNifty50 |
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I would suggest installing new wiring. I would not rely on what you have there.
OldNifty50 |
I 100% agree that new wiring is needed.
OldNifty50 |
Posts: 12 |
I'm down with that! Thanks everyone!!
0 members (),
74
guests, and
8
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
