kevzo22 Offline OP
Hello all,
I recently acquired my great grandfathers 32 confederate and was curious where the clutch pedal return spring attaches to either the frame or a bracket on the trans. Currently it is put together with baling wire, last I checked that was not a standard option. Please se attached pics, any help would be greatly appreciated.
Kevin
One end of the clutch pedal return spring goes on a rivet with hole in the end that fits into the hole in the end of the throwout bearing arm. The other into a hole in the top of the crossmember that is between engine and clutch housing.
