Posts: 39 |
Still attempting to put the 31 Independence on the road for this summer. Next on the agenda is the ammeter gauge. The dial is pegged at -10. No movement either sitting or on the road. Checked the cut out and it functions okay. Not certain if it's the generator or the gauge itself. The dial has two terminals on the back side. One side has three wires attached and the other a single which appears to be going to the light switch, The fuse inline is good. Can an ammeter be repaired easily or need be sent out or replaced?
TedG
Posts: 734 Likes: 14
Posts: 734 Likes: 14 |
Hello Ted1956, Not all that knowledgeable when it comes to electrical issues so I think that isolating the ammeter is what might be the first thing to investigate. Computer search '1931 chevy wiring diagram' for reference if needed. Before unhooking any wires, and the vehicle turned off and all electrically powered items of the vehicle turned off, does the ammeter still indicate neg -10 amps? Would you not think that your battery voltage be depleted rapidly? Does that happen? If you disconnect the battery, does the ammeter still indicate neg -10 amps? If so, I would suspect issues with the ammeter gauge itself. If the ammeter changes it's indication when the battery is disconnected, issues may be elsewhere within the electrical system. I do not know if an ammeter can be repaired if determined to be failed. You may find it helpful to make a checklist of the tests that you make to help in remembering the results and to reduce any head scratching confusion.
Posts: 39 |
Yes the ammeter reads -10 even when the battery is disconnected. It appears to be wired correctly having looked at the wiring schematic. I have ordered a replacement gauge but that was ten days ago and no receipt which is troubling. Assuming it's either a defective gauge or the generator isn't charging. With the horrible weather here in Illinois I haven't driven the car enough to know if the battery is being charged. I have a tender on it in storage currently. The car is a new acquisition so haven't had a road experience with it as of yet.
TedG
Hello Ted1956, Check the battery's voltage without the battery tender connected, by using a DC volt meter (on a DC volt setting higher than the voltage of your battery) and read the voltage at the battery. Start your engine and read the voltage at the battery. You may need to rev the engine above idle speed some. If the voltage reading is more than the batteries static voltage, than your system is charging and your ammeter normally should indicate within the + pos side of the gauge. If there is no charging voltage reading, then the charging system needs attention. This is where my knowledge of the system falls off. What caused the ammeter to go and stay at the neg -10 indication? Will it happen again to a new ammeter? Don't know. But, doing these checks/tests can help to troubleshoot the charging and indicating systems. By the way, (BTW) you did say you have a generator and not an alternator, correct?
Posts: 39 |
It is the original style generator currently. Will follow the suggestion to disconnect the tender and check battery voltage and again running with an engine rev. Ammeter is pegged and frozen at the -10 reading both while idle and running. No change of reading when I apply headlights or horn. Once new gauge arrives I am apprehensive about the install since a reason must have existed to cook the old one. Unless it just retired from old age?
TedG
Hello Ted1956, I was incorrect (wrong), back in the distant past, when I could not remember what polarity to hook up my battery to the 31 Coach. Well, thinking that ALL the old vehicles were positive ground back then before my time. To my shocking outcome it looked like an arc weld as I tried to make the connection. That was a quick learn. I mention this only to call attention to a possible reason an ammeter would bury itself max discharge. Don't know if reverse polarity would do this but it's worth thinking about.
Posts: 39 |
Nice catch! The car had been sitting idle for 12 years prior to my purchase. Seller installed a new battery and very possible he did reverse the polarity for the battery since he was not a car guy. He may have initially installed incorrectly and cooked the ammeter.
TedG
Posts: 885 |
Hello Ted --
My experience is that the amp guage, if working at all will work with either pos or neg ground. The only difference is that with pos ground vs neg ground is that the guage reads plus when reving eng with neg ground and minus when reving with pos ground. That is how I check the electrical system on my 48 Plymouth. Just switch the cables to neg ground and pos cable to starter, than after checking electrical system I go back to pos to ground and neg to starter. The rest of the electrical system doesn't care if its neg or pos ground. Hope I made some sense here and best to ya.
Jim.
Hello Ted1956, Trying to look ahead when you are testing your charging system for proper operation after the new ammeter is installed. I do not know if you are familiar with the need to polarize the voltage regulator and generator with each other or not. You may or may not yet have any of the recommended manuals for your vehicle to reference. Just in case, I'll recommend that you ask the computer "why you need to polarize regulator and generator" and then understanding why, then ask the computer "moss polarizing regulator and generator videos". They are not lengthy videos so I suggest starting them at the beginnings. Just trying to save you from condemning the charging system as broken when maybe it's only a polarization issue. I offer these suggestions because you said that you are new to this vehicle and maybe not that familiar.
Posts: 39 |
New question is this. Now have the new ammeter replacement but concerned I might damage it if installed incorrectly. I understand the need to polarize the generator with a regulator but told my 31 Chevy has a cut off switch and no regulator. What then? The cut off has been tested okay.
TedG
Hello Ted1956, I'd say that you volt meter the battery at static and then with the engine running to verify if the generator is putting out a charge. If not, polarize the generator and see if it charges with engine running. I would think that your ammeter wiring is installed correctly. Look closely at the old ammeter's connections to compare with the wiring diagram. It should be OK to install the new ammeter but make sure that you disconnect the battery before doing it for safety. Once installed, run the engine and retest for battery charging and repolarize generator if needed. Verify ammeter for proper indication.
Posts: 39 |
Appreciate the assist. Will address it once again this coming weekend. Will share the ultimate outcome!
TedG
Posts: 39 |
Changed out both the cut out and ammeter gauge this weekend. Replacement meter functions correctly. In the off position it's now centered at zero. The battery has a tender so assume it is full charge. On the road the new gauge shows +10 amps. It will dip when headlights are on or horn engaged. Is all good to go or need I tone down the generator brush?
TedG
Posts: 19,757 Likes: 62
Posts: 19,757 Likes: 62 |
10 amps is okay but at the high end of OKAY. 12 amps is DANGER of overheating and throwing solder off armature. I set mine as low as I can so I don't boil water from battery on longer trips. It makes up normal starting loss in a few miles or less. Also don't drive at night. If I do resetting third brush in quick and easy.
Posts: 4,023 Likes: 99
Posts: 4,023 Likes: 99 |
I would follow Chipper's guidance.
Remember that in a third brush generator the output is constant regardless of load on the electrical system. The amperage output is determined by the offset between the fixed brush and the third brush. There is no active voltage or current regulation.
Your generator is putting out 10 amps whether the car needs it or not. The ammeter reading drops when you turn on the lights or blow the horn because a portion of the 10 amps is being directed to that function rather than the battery.
I agree with Chipper that unless you plan to drive a lot at night and use the headlights you should consider reducing the charge rate. The lower load lets the generator run cooler and as he noted, is easier on the battery.
Posts: 112 Likes: 2
Posts: 112 Likes: 2 |
End result is the ammeter itself had been stuck. Replaced it with a new one and it went into action. Took the old unit to the work bench and touched the back side with a probe and the needle popped free! Just my luck having just spent $60 on the replacement gauge. At least now I have a spare for the next owner down the road.
Just remember if it stuck once, it likely will stick again.
Posts: 112 Likes: 2
Good point. Fortunately its the new one currently installed.
Let the next guy worry about it? Naw, he won't know it might stick. Problem solved!?
Topics59,071
Posts429,078
Members18,308
