Page 2 of 2 1 2
I suggest that you study this wiring diagram. Based on what I can best determine turn signals were a dealer installed accessory for trucks in 1954. This included adding a second dual filament taillight to the right rear of the bed.
Your latest picture only shows 3 wires in the harness from the steering column. There should be another 3 wire harness going up to the turn signal switch. It has white, pink, and purple wires.
1954 Truck Turn Signals
I am completely confused by the double dual filament tail lights. Until you can trace all the wires to all the filaments I doubt if I can offer much more guidance.
1 member likes this: OldNifty50
I think what I'll do going forward is rewire where I can, cover/protect it with aftermarket conduits and grommets. What gauge wire is recommended?
The tail lights were wired with 16 gauge wire. This larger wire was used because it was a 6 volt system and it was a relatively long length of wire to the taillights.
If your vehicle is really a 12 volt system and you are not concerned what could happen if someone converts it back to 6 volts, you can use 18 gauge wire.
I would suggest installing new wiring. I would not rely on what you have there.
I 100% agree that new wiring is needed.
I'm down with that! Thanks everyone!!
Page 2 of 2 1 2
Support The VCCA!
Member Photos
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
Who's Online Now
3 members (ruscar, Dersh, Tiny), 226 guests, and 8 robots.
Key: Admin, Global Mod, Mod
Newest Members
RiversideRed, Von, Tucker31AE, Spartanpele, Rusty_Old_Nuts
18,032 Registered Users
Today's Birthdays
doneast, edl, Pats29Cabriolet
Forum Statistics
Topics58,613
Posts425,316
Members18,032
Most Online1,133
Jan 22nd, 2020
