did you get the instruction sheet with it ?? have to make sure there is the ridge to press it in against to seat it. also can peen or tack it in place using a punch on the seems of plate and engine. seat it flat and flush. then test fit water pump with gasket to make sure impeller does not hit or rub. if the ridge is gone then you have a little work to do to hold and seat the baffle plate.
